I am able to connect to the TFTP server and download a file to the development kit. The issue is that the example does not state how the firmware file should be generated and uploaded to be compatible with Wiznet’s implementation of DFU. I have tried with the files provided with Nordic’s SDK that Wiznet’s example is built upon, but I get an error saying that the downloaded application is not valid after it is downloaded.
The README file in the example I link to, only shows a picture of a “firmware.bin” file, but does not provide information about how to make this file, what it should contain and how its settings should be.
Thanks for your answer, Mason, that’s much appreciated.
I compile with Keil, and after your advice, I have now used J-Flash to convert the output hex-file to .bin.
I am able to transfer the .bin file to the Development Kit, but i get the following log after the transfer is complete:
0> :INFO:In nrf_bootloader_init
0> :INFO:In real nrf_dfu_init
0> :INFO:running nrf_dfu_settings_init
0> :INFO:Enter nrf_dfu_continue
0> :INFO:Single: Invalid bank
0> :INFO:Enter nrf_dfu_app_is_valid
0> :INFO:Return false in valid app check
0> :INFO:After real nrf_dfu_init
0> :INFO:After nrf_bootloader_init
0> :INFO:Running nrf_bootloader_app_start with address: 0x0001f000
0> :INFO:Disabling interrupts
0> :INFO:Setting SD vector table base: 0x0001f000
And then the application never starts, and it looks like the application is not valid for some reason: “INFO:Return false in valid app check”
The applications I have tried, are from SDK 12.2.
One of them is found in the DFU examples: examples\dfu\ble_dfu_send_hex\test_images_update_nrf52
The other is the Blinky example: examples\ble_peripheral\experimental_ble_app_blinky
None of them works when i convert them to .bin and transfer them via TFTP.
It would be great if an example .bin file that works could be provided here or in the GitHub example so it would be possible to confirm that the setup is correct.
Thanks for your help, Mason, it works now.
The error I did, was using SoftDevice v3.0.0 that was provided with SDK 12.2. Switching to SoftDevice v3.1.0 solved the problem.
It would be really great with a similar example to the one you have already created, but for nRF52840 using SDK 14.2.
I have been able to establish connection from a nRF52840 and WIZ5500io moduoe to the TFTP server and seemingly download the file, but application is not running. When reading the memory address where the application should be placed it only contains the letters “meout 5” followed by zeros, which suggests the connection timeouts and not actually downloads anything. An example for how to do this properly would be much appreciated.
Update: Using Wireshark I’m able to see that all data is transferred and ACK’ed as it should. The problem must be on the firmware side when copying the data to the application region.
