i want to use the W5500 in a Master Controller.
Currently i copied the Reference Schematic of the “W5500 Ethernet Shield” as i don´t have a single clue on how to design the schematic around Magjacks (J1B1211CCD currently used as in reference).
Now here is the Problem: My Board will sit very flat on a surface and the Tab Down Connectors are not an option,
So i searched for Tab-Up Magjacks and Arrived at this Molex Part: Molex Datasheet.
This Connector from Molex does not have the Center Taps (ct) routed out, but connected internally to chassis ground with a bunch of 75 Ohm Resistors.
Question is now: What is the best way of connecting this Jack to the W5500 (looking for the schematic).
or: Is there a Recommended Connector that has the Tab facing up and is Placed ontop of the Board (Nod Mid-placed like the one on the W5500 Ethernet Shield).
I would really appreciate your help.
Best Regards,
Tibor
