If User wants to factory states, use the following method.
Factory state setting is reset to the default value.
It setting to configuration information(serial&network setting and so on) of the product to the factory setting.
- Connect LAN cable to product and search (Broadcast) with configuration tool.
- After the search, you can use the “Factory” icon at the top of the configuration tool.
After you click to Factory icon, modules configuration setting is all reset. And module is reset.
