By using W5500-EVB what is the best way to interface industrial analog sensors with I2C based AD converters using standard Ethernet protocols?
Never tried this but you should search out for shield of I2C protocols which is easy to make master slave connections and also please go through the manual What exactly you wanna use AD converters with W5500-EVB?
