i uploaded firmware as flash programming as i done before, but now the blue light is not showing now. previously it was there when i uploaded the firmware, but it not now. when i upload the firmware, it shows a sudden bluelight and then no bluelight.
Did you use the ISP program when uploading firmware?
If you did not check the ‘Erase all code block’ option, the data area of memory may have been cleared.
First, connect the device using the USB type B cable and check the debug message.
Hi Rena,
I have same issue. I programmed it using wizconfig-V1.0.0.exe. Firmware updated okay.
After programming blue light doesn’t glow. Also it doesn’t detect on above utility.
I also managed to recover it. But then how to program it?
Please help.
Compiled this code in Keil without any changes in source code.
I updated firmware using config tool. For updation I used binary file “W7500x_S2E_App.bin” from “WIZ750SR-1.2.4\WIZ750SR-1.2.4\Projects\S2E_App\bin” path.
I found same issue.
So I again updated file using config tool with binary file “WIZ750SR-1xxv124.bin”. Then it is working fine. Means I only updating App part. So there is no requirement of WIZISP.
It is not working only when I complied source code and using this binary file.
Is there any issue with source code or starting address?
Starting address of IROM1 is 0x7000 and IRAM1 is 0x20000000.
Which device are you using?
The firmware used in WIZ750SR and WIZ750SR-1xx is different.
Github WIZ750SR repository’s code is based on WIZ750SR.
If you are using a WIZ750SR-1xx device, you should modify define code.
Please refer to W7500x_board.h
