Hello!
Please help me with configuration
I have a problem with configuration my wizfi210 cant find any routers:
Here some pics:
Here quite different from the manual. In manual here should be “CP2101 USB to UART Bridge Controller” , but mine is like a serial (I installed all drivers) freeimagehosting.net/6f3im
Second is WizSmartScript could find WizFI210 but next step: He couldnt find any routers freeimagehosting.net/79ix5
Do the AP-Scan again using <AT+WS> command with serial-terminal, manually.[/quote]
Thank you for reply.
I think also maybe problem is an Antenna by the way antenna was broken(I took from my friend) freeimagehosting.net/9qo5r and I tried to recover it. Maybe it was wrong idea just using soldering. Do you have idea with recovering or in general ? maybe there are some solutions with an Antenna???
