Hi There,
I am trying to get W5500 work as a TCP Server.
As initial steps, I first provided a static IP address so that I could test the spi connectivity between stm32f103xx microcontroller and w5500.
I have successfully programmed an IP address, Subnet mask, MAC Address and gateway address by using the VDM mode and writing to Common Register 0x0001-0x0012.
I pinged the w5500 and got a response and also did an arp -a to check the programmed MAC address.
both ping and arp were successful.
So far all is good. I have the following issues:
Issue 1:
Next I tried to read the programmed MAC address that I was able to see using the arp command.
I did the following
Sent address High = 0x00, address Low = 0x09 and control = 0x00.
The SPI mode is 0 and the host configured as the Master.
I have activated SPI interrupt. So in the ISR I am checking" if((SPI1->SR & SPI_SR_RXNE) == SPI_SR_RXNE)" for any received data packets.
I was expecting to receive the MAC Address but received 0x00 zeros.
Next I tried reading the Version so wrote address High = 0x00, address Low = 0x39 and control = 0x00, but again received Zeros.
Note: All my write are successful and I receive a 0x01,0x02,0x03.
Issue 2:
Each time I open socket 0 by writing to Sn_Cr register, I cannot even ping the W5500.
I am using 3.3V, Port A PA4,5,6,7 for SPI1 on stm32f103xx.
I have connected the interrupt pin of W5500 to PB15.
Both port A and port B of stm32f103xx are activated in RCC, AFIO for SPI1 is activated.
Dear Eugeny,
Thanks for your prompt response.
I am for some reason not getting 0x01,0x02,0x03 for read.
To read the version number, I am transmitting the following:
Address High Byte = 0x00, Low Byte = 0x39
BSB,RWB,OM = 0x00
I keep the Chip select line low so that I can sequentially receive data but I only receive a couple of 0x00s.
For the second problem regarding Socket 0:
I am doing the following to open TCP socket and then listen to it:
To Select TCP - Address High Byte = 0x00, Address Low Byte = 0x00, BSB,RWB,OM (VDM) = 0x0C and data = 0x21 (To enable ND/NC/MMB and TCP)
I specify port number as 9000 (in hex 0x23,0x28), I write the following to the W5500 - Address High Byte = 0x00, Address Low Byte = 0x04, BSB,RWB,OM (VDM) = 0x0C and data = 0x23, 0x28
I enable the socket interrupt - Address High Byte = 0x00, Address Low Byte = 0x2C, BSB,RWB,OM (VDM) = 0x0C and data = 0x1F
I set RX Buf size as Address High Byte = 0x00, Address Low Byte = 0x1E, BSB,RWB,OM (VDM) = 0x0C and data = 0x02 (2Kb)
I set TX Buf size as Address High Byte = 0x00, Address Low Byte = 0x1F, BSB,RWB,OM (VDM) = 0x0C and data = 0x02 (2Kb)
Socket OPEN - Address High Byte = 0x00, Address Low Byte = 0x01, BSB,RWB,OM (VDM) = 0x0C and data = 0x01
Socket Listen - Address High Byte = 0x00, Address Low Byte = 0x01, BSB,RWB,OM (VDM) = 0x0C and data = 0x02
Socket open and listen are in the CR register 0x00, 0x01.
When I write I immediately pull the CS line up after the last byte is written and I receive 0x01,0x02,0x03.
However for read I let the CS line low so that I can read sequentially but do not receive any valid data, only Zeros.
Am I missing something?
Your help would be most appreciated.
Thanks,
SR
