WIZ127SR same IP address and Port?
I am considering using the WIZ127SR for an application we have, but it is not clear if the two UARTs must have different IP address and Port settings.
Ideally I would like to set UART 1 to one baud rate and UART 2 to another board rate but have the data from the two UARTs be transmitted as UDP packets with the same Port number, so that an application can just open one socket and receive the data from both UARTs.
Does anyone know if this is possible ?
Best regards
Sumps
It’s possible. :smiley:
