I am using the W7500P-S2E on a self developed Board.
I got a problem with the RS232->Ethernet Signal.
Receiving from the Ethernet:
Received Data goes trough on the U_TXD0 (PA13/Pin43). It is functional and an other RS232 Device gets the Data. Works fine.
Sending back on the U_RXD0 (PA14/Pin44) is correctly but from there… nothing on the Ethernet. Stays dead silent. -> The signal comes correctly on the W7500P Pin44.
No cases similar to yours have ever been reported.
If you post the hardware design, such as the schematic or gerber file of your board, we will review it and give you the results.
Thanks for the help.
It was just the missing connection between Pin14 and Pin23.
In total it was my fault using the wrong version of the datasheet. I used v1.0 instead of v1.2.
Also thanks for the fast contact and support via email.
