I am working with an arduino mega with W5500 Ethernet Shield (the red one from wiznet).
I am writing a bootloader.
Here is a very basic bootloader:
int main(void)
_delay_ms(500);
// Spi init
SPI_PORT = _BV(SCK) | _BV(MISO) | _BV(MOSI) | _BV(SS);
SPI_DDR = _BV(SCK) | _BV(MOSI) | _BV(SS);
ETH_PORT |= _BV(ETH_SS);
ETH_DDR |= _BV(ETH_SS);
SD_PORT |= _BV(SD_SS);
SD_DDR |= _BV(SD_SS);
SPSR = (1 << SPI2X);
_delay_ms(500);
// Network init
for (int i=0; i<8 ; i++) // MAX_SOCK_NUM
uint8_t cntl_byte = (0x0C + (i<<5));
spiWriteReg(0x1E, cntl_byte, 2);//0x1E - Sn_RXBUF_SIZE
spiWriteReg(0x1F, cntl_byte, 2);//0x1F - Sn_TXBUF_SIZE
uint8_t registerBuffer[28] = {
0x80, // MR Mode - reset device
// EEPROM block starts here
192,168,0,254, // GWR Gateway IP Address Register
255,255,255,0, // SUBR Subnet Mask Register
0xDE,0xAD,0xBE,0xEF,0xFE,0xE0, // SHAR Source Hardware Address Register
192,168,0,100, // SIPR Source IP Address Register
// EEPROM block ends here
0, 0, // Interrupt Low Level Timer (INTLEVEL0), (INTLEVEL1) (0x0013, 0x0014)
0, // IR Interrupt Register (0x0015)
0, // IMR Interrupt Mask Register (0x0016)
0, // Socket Interrupt (SIR) (0x0017)
0, // Socket Interrupt Mask (SIMR) (0x0018)
0x07, 0xd0, // RTR Retry Time-value Register ((RTR0),(RTR0)) (0x0019,0x001A)
0x08, // RCR Retry Count Register (0x001B)
for(int i = 0; i < 28; i++)
spiWriteReg(i, 0x04 , registerBuffer[i]);
I do not understand why but i have to wait about 30 seconds between power up and the first ping response.
Why does w5500 takes 30 seconds to setup ?
I have tried the same program on old officiel arduino Ethernet Shield 2 and i do not have this problem.
This shield has the same w5500 chip…
Thanks
