Now I begin to study ths chip The problem is - common MR allways readed as 0 But other regs may be written fnd realed correct
Why did you decide that it is a problem? What you expect to read from there and when (after what actions)?
Did you read the datasheet?
I try to set PB and FARP bits to MR but register readed as 0. But GAR , SUBR registers I can write and read correct. PHYCFGR and VERSION registers also readed correct. And - device did no connect LINKLED and ACTLED flased in ~1sec interval
What exact value(s) you write to common MR register?
Check the address value of MR register and if you set RST bit MR register.
Setting RST to 1 resets all register values.
