Hi, how can I set Auto Connection to UDP server mode?
TCP mode works:
[ul]
AT+NAUTO=1,1,5000
[OK]
[/ul]
UDP mode don’t work:
[ul]
AT+NAUTO=1,0,5055
[ERROR: INVALID INPUT]
[/ul]
Non-auto UDP server mode works.
WizFi210
1.1.0.5(W)
TCP mode works:
[ul]
AT+NAUTO=1,1,5000
[OK]
[/ul]
[ul]
AT+NAUTO=1,0,5055
[/ul]
WizFi210
1.1.0.5(W)
Hello vstelegin
FW 1.1.0.x support TCP-Server, TCP-Client and UDP-Client mode.
But, FW 1.2.0.x support TCP-Server, TCP-Client, UDP-Server and UDP-Client mode.
If you want to use UDP-Server using <at+nauto=1,0,5055>, you need to use FW 1.2.0.x.
Thank you for the information, but I can find only 1.1.1.0 firmware version.
Hi
For downloading other firmware like SPI or Enteprise, please contac to our local office.
thank you.
what is the stack size of a wizfi 210 module…and also can you provide me any sample code if possible…
thanks.
