I found document “WIZ14xSR Configuration Message Structure and Message Flow” which describe communication beetwen host and end device. In this document, i can’t find any information about remote reset of device. Is possible reset device from eth port? For example WIZ107SR has implemented RESET command throu network port. I need it because in error situation when connection between host and converter is broken (ex. broken cable), port in device is still opened and i can’t reconnect till reset isn’t trigered (now I turn off power from device). Do you have any method/idea to close all ports when device is pingable again after error?
