Dear support team,
Recently I investigated one issue reported by our customer and had one finding of W5300. In this scenario, W5300 acts as a TCP client. It sends a request and then receives a packet from the 3rd party TCP server.
In the test, we made TCP server reply the same data every time so W5300 should read exactly same data stream every time, thus our firmware should read the same data as well.
We found sometimes certain bytes are missed in the raw data our firmware reads from W5300 RX FIFO. The phenomenon is as below.
In correct transactions, the response bytes our firmware reads from W5300 RX FIFO is:
00 3F 00 6E 00 00 00 39 6E 03 36 F9 A0 9F FF D5 54 81 FF E0 07 C3 FF 11 FF 00 00 FF FA 18 FF FF F5 3F FF 24 A9 FF F9 C0 00 7F DF FF FD 00 00 00 01 AF FF BF 1F FF FA FF FF FF FF 55 5F FD B5 01 FF
In the wrong transactions, the response bytes our firmware reads from W5300 RX FIFO turns out to be:
00 3F 00 6E 00 00 00 39 6E 03 36 F9 A0 9F FF D5 54 81 FF E0 07 C3 FF 11 FF 00 00 FF FF FF F5 3F FF 24 A9 FF F9 C0 00 7F DF FF FD 00 00 00 01 AF FF BF 1F FF FA FF FF FF FF 55 5F FD B5 01 FF 01 FF
You can see that in the wrong transaction, two bytes FA 18 were missed in the data stream, but the length in PACKET-INFO (we do not use alignment mode) still gives the expected full length (63), so the firmware tries to read the full length (63) of bytes from W5300, thus two another tailing bytes read from W5300.
In further investigation, I used logical analyzer and found the actual signals we read from W5300. It shows that the bytes are electronically missed from W5300, not somewhere else in our firmware. Please refer to following screenshot.
You can see in the circled window, the expected bytes FA 18 are missed in the data stream from W5300 RX FIFO. CS, RD signals and data bus are operated as required by W5300 specification.
And we found different W5300 chips have different performance.
The chips with following print DO NOT have this issue on our product.
The chips with following print HAVE this issue.
We have confirmed the other parts on our Ethernet interface board are same; the only difference is the W5300 chip.
I am still investigating more samples in our stock to verify this finding.
But as I described above, we have had the evidence that different W5300 chips performed differently on our products.
I appreciate if you can provide more details about the technical difference between two chips indicated in the above pictures, or advise us if you have similar findings before.
Thanks a lot!
