About the W6100 category
(Replace this first paragraph with a brief description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters.)
Use the following paragraphs for a longer description, or to establish category guidelines or rules:
  • Why should people use this category? What is it for?
  • How exactly is this different than the other categories we already have?
  • What should topics in this category generally contain?
  • Do we need this category? Can we merge with another category, or subcategory?
Is it possible use W6100 by bypassing its TCP/IP stack?
My host controller uses a LWIP stack that controls other interfaces too. So, I would like to just use the PHY or MAC/PHY of W6100.
If yes, could you point me to example codes if they are available?
w6100을 쓰고 있습니다.
TCP Window Full 이 발생하는데요. 해결할 API가 존재 할까요?
