hi all, im using Eth wiz click and im having some troble interpretating the data sent.
Lest say I send a number 5 via a TCP client, I want to be able to read that number through SPI via a microcntoller.
Right now im using a example, wich allows to ping the module and to echo any UDP or TCP package.
But how do you obtain the data?? I see the datasheet talks about the frames
and that the return is by
send(SOCK_ID_TCP, gDATABUF + sentsize, size - sentsize)
but cannot get it to work, any ideas?
im using the fillowing code in MikroC
thanks.
include "Wizchip_Conf.h" #include "W5500.h" #include "Socket.h" // ETH WIZ click connections sbit Wizchip_Rst at LATE1_bit; sbit Wizchip_CS at LATE0_bit; sbit Wizchip_Rst_Direction at TRISE1_bit; sbit Wizchip_CS_Direction at TRISE0_bit; // end of ETH WIZ click connections // Socket & Port number definition #define SOCK_ID_TCP 0 #define SOCK_ID_UDP 1 #define PORT_TCP 5000 #define PORT_UDP 10001 #define DATA_BUF_SIZE 1024 uint8_t gDATABUF[DATA_BUF_SIZE]; volatile wiz_NetInfo gWIZNETINFO = { {0x00, 0x14, 0xA3, 0x72, 0x17, 0x3f}, // Source Mac Address {192, 168, 0, 53}, // Source IP Address {255, 255, 255, 0}, // Subnet Mask {192, 168, 0, 1}, // Gateway IP Address {192, 168, 0, 1}, // DNS server IP Address NETINFO_STATIC }; volatile wiz_PhyConf phyConf = { PHY_CONFBY_HW, // PHY_CONFBY_SW PHY_MODE_MANUAL, // PHY_MODE_AUTONEGO PHY_SPEED_10, // PHY_SPEED_100 PHY_DUPLEX_FULL, // PHY_DUPLEX_HALF }; volatile wiz_NetInfo pnetinfo; // brief Call back function for WIZCHIP select. void CB_ChipSelect(void) { Wizchip_CS = 0; } // brief Call back function for WIZCHIP deselect. void CB_ChipDeselect(void) { Wizchip_CS = 1; } // brief Callback function to read byte usig SPI. uint8_t CB_SpiRead(void) { return SPI1_Read(0xAA); } // brief Callback function to write byte usig SPI. void CB_SpiWrite(uint8_t wb) { SPI1_Write(wb); } // brief Handle TCP socket state. void TCP_Server(void) { int32_t ret; uint16_t size = 0, sentsize = 0; // Get status of socket switch(getSn_SR(SOCK_ID_TCP)) { // Connection established case SOCK_ESTABLISHED : { // Check interrupt: connection with peer is successful if(getSn_IR(SOCK_ID_TCP) & Sn_IR_CON) { // Clear corresponding bit setSn_IR(SOCK_ID_TCP,Sn_IR_CON); } // Get received data size if((size = getSn_RX_RSR(SOCK_ID_TCP)) > 0) { // Cut data to size of data buffer if(size > DATA_BUF_SIZE) { size = DATA_BUF_SIZE; } // Get received data ret = recv(SOCK_ID_TCP, gDATABUF, size); // Check for error if(ret <= 0) { return; } // Send echo to remote sentsize = 0; while(size != sentsize) { ret = send(SOCK_ID_TCP, gDATABUF + sentsize, size - sentsize); // Check if remote close socket if(ret < 0) { close(SOCK_ID_TCP); return; } // Update number of sent bytes sentsize += ret; } } break; } // Socket received the disconnect-request (FIN packet) from the connected peer case SOCK_CLOSE_WAIT : { // Disconnect socket if((ret = disconnect(SOCK_ID_TCP)) != SOCK_OK) { return; } break; } // Socket is opened with TCP mode case SOCK_INIT : { // Listen to connection request if( (ret = listen(SOCK_ID_TCP)) != SOCK_OK) { return; } break; } // Socket is released case SOCK_CLOSED: { // Open TCP socket if((ret = socket(SOCK_ID_TCP, Sn_MR_TCP, PORT_TCP, 0x00)) != SOCK_ID_TCP) { return; } break; } default: { break; } } } // brief Handle UDP socket state. void UDP_Server(void) { int32_t ret; uint16_t size, sentsize; uint8_t destip[4]; uint16_t destport; // Get status of socket switch(getSn_SR(SOCK_ID_UDP)) { // Socket is opened in UDP mode case SOCK_UDP: { // Get received data size if((size = getSn_RX_RSR(SOCK_ID_UDP)) > 0) { // Cut data to size of data buffer if(size > DATA_BUF_SIZE) { size = DATA_BUF_SIZE; } // Get received data ret = recvfrom(SOCK_ID_UDP, gDATABUF, size, destip, (uint16_t*)&destport); // Check for error if(ret <= 0) { return; } // Send echo to remote size = (uint16_t) ret; sentsize = 0; while(sentsize != size) { ret = sendto(SOCK_ID_UDP, gDATABUF + sentsize, size - sentsize, destip, destport); if(ret < 0) { return; } // Update number of sent bytes sentsize += ret; } } break; } // Socket is not opened case SOCK_CLOSED: { // Open UDP socket if((ret=socket(SOCK_ID_UDP, Sn_MR_UDP, PORT_UDP, 0x00)) != SOCK_ID_UDP) { return; } break; } default : { break; } } } // brief Initialize modules static void W5500_Init(void) { // Set Tx and Rx buffer size to 2KB uint8_t buffsize[8] = { 2, 2, 2, 2, 2, 2, 2, 2 }; Wizchip_Rst_Direction = 0; // Set Rst pin to be output Wizchip_CS_Direction = 0; // Set CS pin to be output CB_ChipDeselect(); // Deselect module // Reset module Wizchip_Rst = 0; Delay_ms(1); Wizchip_Rst = 1; Delay_ms(1); SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV4, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH); // Wizchip initialize wizchip_init(buffsize, buffsize, 0, 0, CB_ChipSelect, CB_ChipDeselect, 0, 0, CB_SpiRead, CB_SpiWrite); // Wizchip netconf ctlnetwork(CN_SET_NETINFO, (void*) &gWIZNETINFO); ctlwizchip(CW_SET_PHYCONF, (void*) &phyConf); } void main() { //SLRCON = 0; W5500_Init(); wizchip_getnetinfo(&pnetinfo); while(1) { // TCP Server TCP_Server(); // UDP Server UDP_Server(); } }
