I need to update the WIZ750SR firmware from my own software, by ethernet connection.
I just found the WIZ750SR Command manual (link below). It is useful to discover the connected devices, but the firmware update commands are not described. Is there any documentation of the ethernet protocol to update the firmware? Thanks!
WIZ750SR’s firmware is divided into App and Boot areas.
Which part have you modified?
If you modified only the App part, you can use the configuration tool to update F/W with network.
You can download the configuration tool from below link.
