Configure module by TCP/IP
After I connect to the wizfi250 network, can I configure the module send AT commans by TCP/IP?
How I can send TCP/IP comand for configure module?
Hi
Please refer to this URL in order to use AT commands for configure TCP/IP setting.
[url]http://wizwiki.net/wiki/doku.php?id=products:wizfi250:wizfi250pg:start#at_scon[/url]
And for the more information, refer to section of “Examples-Data Communication” in this wiki page.
If you want to use AT command through TCP/IP communication, WizFi250 can’t use this function.
Do you now another module, were i can use AT command through TCP/IP communication for configure the module?
Hello JavierAleman
Because some-AT-commands needs disassociation or reboot, it’s not easy to issue AT-commands via TCP-IP.
