I have problem with build of ioLibrary_BSD in Keil IDE. I add to my project Ethernet and Internet directories and during build I have got following errors:
compiling wizchip_conf.c...
..\Ethernet\wizchip_conf.c(97): error: #29: expected an expression
..\Ethernet\wizchip_conf.c(98): error: #29: expected an expression
..\Ethernet\wizchip_conf.c(99): error: #29: expected an expression
..\Ethernet\wizchip_conf.c(100): error: #29: expected an expression
..\Ethernet\wizchip_conf.c(101): error: #29: expected an expression
..\Ethernet\wizchip_conf.c(102): error: #29: expected an expression
..\Ethernet\wizchip_conf.c(103): error: #29: expected an expression
..\Ethernet\wizchip_conf.c(104): error: #29: expected an expression
lines where errors occur:
.id = _WIZCHIP_ID_,
.if_mode = _WIZCHIP_IO_MODE_,
.CRIS._enter = wizchip_cris_enter,
.CRIS._exit = wizchip_cris_exit,
.CS._select = wizchip_cs_select,
.CS._deselect = wizchip_cs_deselect,
.IF.BUS._read_byte = wizchip_bus_readbyte,
.IF.BUS._write_byte = wizchip_bus_writebyte
I have also one warring:
..\Internet\DHCP\dhcp.c(577): warning: C4017W: type may be used before being set
in line:
uint8_t type;
Thanks you in advance for your help.
