You say “So we decided that we did not need to present 0x10 to the document.”, yet on pages 78-80 of the W5300 datasheet (version 1.3.3) Wiznet did chose to document the following “temporary status” states of the socket status register: 0x15 SOCK_SYNSENT, 0x16 SOCK_SYNRECV, 0x18 SOCK_FIN_WAIT, 0x1B SOCK_TIME_WAIT, 0x1D SOCK_LAST_ACK, 0x01 SOCK_ARP. I cannot imagine why you would fail to document 0x10.
You say “Under normal circumstances, a timeout occurs because no response is received from the server and becomes a closed state . Or it receives a SYN ACK from the server and becomes an established state.” Yes, that is what I expect. I call connect(), then wait for socket status to change to either SOCK_ESTABLISHED (indicating the connection was successful), or SOCK_CLOSED (indicating the connection failed (was refused, or timed out). This is what I expect to happen, either connection established, or socket closed.
Is this the correct way to handle a connection (call connect(), then wait for SOCK_ESTABLISHED or SOCK_CLOSED)? It seems to be what is documented.
Yet sometimes I wait forever, getting neither SOCK_ESTABLISHED nor SOCK_CLOSED. Instead I see socket status 0x10 persisting forever. When this happens, my system is locked up and needs to be power-cycled.
I would be happy to provide you with a wireshark capture of what happens when the W830MJ sends a SYN, but I have a problem doing that. Most of the time it works as expected, giving me SOCK_ESTABLISHED (or in rare cases SOCK_CLOSED if the server is not available). I have attempted to duplicate the socket status 0x10 problem in my lab, and after months of testing have seen the problem appear exactly one time. But that doesn’t mean this is not a serious problem. My customer has hundreds of these systems installed in the field operating on a live network, and failures are happening at a rate of many failures per week. It is not practical for me to do wireshark captures on all of the customer’s systems. Even if I wanted to, I would not be allowed to because the systems are operating on the customer’s live network, and I am not allowed to connect anything to that live network. The network is used for critical safety systems.
I think a better approach would be for you (or a more knowledgeable programmer) to review the code and figure out how the socket status can be stuck forever at 0x10. Then perhaps you or someone else can suggest a work around that I can implement in my software to get around the bug in the W830MJ. Clearly the work around in the errata sheet does not fix the problem. I am asking for help. Can anyone at Wiznet help me?
