I am running the WIZ750SR in TCP Server mode and when I try to connect to it I get “Connection refused”. I scanned the device for open ports and only the port (50001) for Settings seems to be open, port 5000 is closed.
The weird thing is that the setup was already running like this before but now it does not work anymore. I have no clue as to what changed.
Here are my settings from the debug terminal:
WIZ750SR
>> WIZnet Serial to Ethernet Device
>> Firmware version: 1.2.4 Stable
- Device name: WIZ750SR
- Device mode: TCP_SERVER_MODE
- Network settings:
- Obtaining IP settings: [Static]
- TCP/UDP ports
+ S2E data port: [5000]
+ TCP/UDP setting port: [50001]
+ Firmware update port: [50002]
- TCP Retransmission retry: [8]
- Search ID code:
- Disabled: [None]
- Ethernet connection password:
- Disabled (TCP server / mixed mode only)
- Connection timer settings:
- Inactivity timer: Disabled
- Reconnect interval: [3000] (msec)
- Serial settings:
- Data UART port: [UART0]
+ UART IF: [RS-232/TTL]
+ 115200-8-N-1 / Flow control: NONE
- Debug UART port: [UART2]
+ 115200-8-N-1 / NONE (fixed)
- Serial data packing options:
- Time: Disabled
- Size: Disabled
- Char: Disabled
- Serial command mode switch code:
- Enabled
- [2B][2B][2B] (Hex only)
- Hardware information: Status pins
- Status 1: [PA_10] - PHY link
- Status 2: [PA_01] - TCP connection
- Hardware information: User I/O pins
- UserIO A: [PC_13] - Digital / Input
- UserIO B: [PC_12] - Digital / Input
- UserIO C: [PC_09] - Digital / Input
- UserIO D: [PC_08] - Digital / Input
# MAC: 00:08:DC:54:8A:6F
# IP : 192.168.30.48 / Port: 5000
# GW : 192.168.30.1
# SN : 255.255.254.0
# DNS: 8.8.8.8
SEG:AT Mode
And when scanning the ports with nmap this is the result:
Starting Nmap 7.01 ( https://nmap.org ) at 2019-05-10 16:49 CEST Nmap scan report for 192.168.30.48 Host is up (0.00013s latency). Not shown: 999 closed ports PORT STATE SERVICE 50001/tcp open unknown MAC Address: 00:08:DC:54:8A:6F (Wiznet) Nmap done: 1 IP address (1 host up) scanned in 1.62 seconds
Any ideas what could be wrong here?
