In W5100 schematic there is a inductor between analog and digital ground. What is its value?
Do I use a ferrite bead or I can use a normal inductor ?
Regards
Regards
As far as I know, you have to use ferrite bead.
Because the inductor(FB2) was used “HB-1M1608-121” in the W5100E01- AVR schematic.
Please refer to as below.
Schematic : [url]http://www.wiznet.co.kr/UpLoad_Files/ReferenceFiles/SCHEMATICs_W5100E01-AVR.zip[/url]
part list : [url]http://www.wiznet.co.kr/UpLoad_Files/ReferenceFiles/partlist_W5100E01-AVR.zip[/url]
thanks,
What is exact value of inductor FB2 in this circuit ? ( as you mentioned its part no. is “HB-1M1608-121” )
I saw in the schematic that the digital ground ( GNDD ) and analog ground ( GNDA ) pins of the chip is tied together. Is it right ? I must short these pins ?
Regards.
You have to use 0.5A or 0.3A/120 ohm or 60 ohm as Ferrite bead value and we use the “HB-1M1608-121”.
I recommend that these pins(GNDD/GNDA)is connected to Ferrite bead for stability.
thanks,
