Hi i was trying to find some post with the same issue, but mine is a little diferent, i plug the cable and can´t get no link led. but i debbug my code and i can go until the listen stage. a few times when i press conect from hercules ussing the tcp client i can conect, the most times, don´t i´m also checking the link bit on PHYCFGR and always is set.
regards
Circuit diagram and board picture please.
You have link bit set even when cable is not plugged in?
Hi thanks for your repply, this is mi circuit,
and Yes, i get PHYCFGR =
187, 10111011 without the cable.
Regards
And this is the transformer squematic würst 749010013.
thank you.
