Wiz830mj module
We have send Parallel data to pc from our Embedded circuit using tcp/ip. For this we want use wiz830mj module.Pls conform whether we can load parallel data of 4lines in to wiz830MJ using strobe pulse on separate line, without using Micro controller
I don’t understand exaclty what you want.
Can you explain to me more detail?
Can you draw a simple block diagram about that?
