I have the WIZ550S2E serial-to-Ethernet converter chip. I’m having a little trouble with sending and receiving data. It seems to send just fine, but when receiving data from the Ethernet side of the chip, it seems to add several bits of data to the data packet.
For context, I have performed a loopback test to confirm that data is being sent correctly. I have set up a static IP and I have configured it using the Configuration Tool. I have also set up a virtual serial port using the WIZVSP.
Thoughts?
