WIZ550S2E problem with MQTT
I have a problem with establishing a connection with the mqtt broker. I uploaded the latest 1.3 firmware. If I do not give any subscribe and publish topic, the module connects correctly. Unfortunately, if I give it, the module connects and immediately disconnects, which blocks my entire broker and nothing works.
I just noticed that the problem only occurs if you set up a Publish topic. When it is not set, everything works. I can send data via subscribe topic.
Hello, @dziob,
I set up pub/sub topic for WIZ550S2E but it works well. (establishing a connection & send data)
I think need to check the set options.
Please capture and upload the configuration tool screen.
I will check and respond.
