Hi:
I try to use serial CMD to set the mode 6(multi bridge).
But after I restart the module, the mode goes back to the previous one.
If I set up the mode by web interface, the latest can be remembered.
Please tell me why
Hi
I think you don’t use command. command is command for writing to flash memory.
So If you use this command, WizFi630 will save command.
