[quote=“hjjeon0608”]Hi,
I think CR register address is wrong maybe because Sn_CR always change 0 after performing command.
But your chip and code fall into infinite loop, so there is some problem.
Please check Sn_CR register address.
Best regards.[/quote]
Thank You for reply,
#ifndef SOCKET_H_
#define SOCKET_H_
#define MAX_SOCK_NUM 4 /**< Maxmium number of socket */
#define DEF_IINCHIP_SPI_MODE 3
#define DEF_IINCHIP_MAP_BASE 0x8000
#define COMMON_BASE 0x0000
//typedef uint8 SOCKET;
#define TX_RX_MAX_BUF_SIZE 2048
#define TX_BUF 0x1100
#define RX_BUF (TX_BUF+TX_RX_MAX_BUF_SIZE)
/* WIZNET WRITE/READ /
#define WIZNET_WRITE_OPCODE 0xF0
#define WIZNET_READ_OPCODE 0x0F
/* WIZNET COMMON REGISTERS /
#define MR 0x0000 //MODE REGISTER
@brief Gateway IP Register address
#define GAR0 (COMMON_BASE + 0x0001)
@brief Subnet mask Register address
#define SUBR0 (COMMON_BASE + 0x0005)
@brief Source MAC Register address
#define SHAR0 (COMMON_BASE + 0x0009)
@brief Source IP Register address
#define SIPR0 (COMMON_BASE + 0x000F)
@brief Interrupt Register
#define IR (COMMON_BASE + 0x0015)
@brief Interrupt mask register
#define IMR (COMMON_BASE + 0x0016)
@brief Timeout register address( 1 is 100us )
#define RTR0 (COMMON_BASE + 0x0017)
@brief Retry count reigster
#define RCR (COMMON_BASE + 0x0019)
@brief Receive memory size reigster
#define RMSR (COMMON_BASE + 0x001A)
@brief Transmit memory size reigster
#define TMSR (COMMON_BASE + 0x001B)
@brief Unreachable IP register address in UDP mode
#define UIPR0 (COMMON_BASE + 0x002A)
@brief Unreachable Port register address in UDP mode
#define UPORT0 (COMMON_BASE + 0x002E)
/* WIZNET SOCKET REGISTERS /
@brief socket register
#define CH_BASE (COMMON_BASE + 0x0400)
@brief size of each channel register map
#define CH_SIZE 0x0100
@brief socket Mode register
#define Sn_MR(ch) (CH_BASE + ch * CH_SIZE + 0x0000)
@brief channel Sn_CR register
#define Sn_CR(ch) (CH_BASE + ch * CH_SIZE + 0x0001)
@brief channel interrupt register
#define Sn_IR(ch) (CH_BASE + ch * CH_SIZE + 0x0002)
@brief channel status register
#define Sn_SR(ch) (CH_BASE + ch * CH_SIZE + 0x0003)
@brief source port register
#define Sn_PORT0(ch) (CH_BASE + ch * CH_SIZE + 0x0004)
@brief Peer MAC register address
#define Sn_DHAR0(ch) (CH_BASE + ch * CH_SIZE + 0x0006)
@brief Peer IP register address
#define Sn_DIPR0(ch) (CH_BASE + ch * CH_SIZE + 0x000C)
@brief Peer port register address
#define Sn_DPORT0(ch) (CH_BASE + ch * CH_SIZE + 0x0010)
@brief Maximum Segment Size(Sn_MSSR0) register address
#define Sn_MSSR0(ch) (CH_BASE + ch * CH_SIZE + 0x0012)
@brief Protocol of IP Header field register in IP raw mode
#define Sn_PROTO(ch) (CH_BASE + ch * CH_SIZE + 0x0014)
@brief IP Type of Service(TOS) Register
#define Sn_TOS(ch) (CH_BASE + ch * CH_SIZE + 0x0015)
@brief IP Time to live(TTL) Register
#define Sn_TTL(ch) (CH_BASE + ch * CH_SIZE + 0x0016)
@brief Transmit free memory size register
#define Sn_TX_FSR0(ch) (CH_BASE + ch * CH_SIZE + 0x0020)
@brief Transmit memory read pointer register address
#define Sn_TX_RD0(ch) (CH_BASE + ch * CH_SIZE + 0x0022)
@brief Transmit memory write pointer register address
#define Sn_TX_WR0(ch) (CH_BASE + ch * CH_SIZE + 0x0024)
@brief Received data size register
#define Sn_RX_RSR0(ch) (CH_BASE + ch * CH_SIZE + 0x0026)
@brief Read point of Receive memory
#define Sn_RX_RD0(ch) (CH_BASE + ch * CH_SIZE + 0x0028)
@brief Write point of Receive memory
#define Sn_RX_WR0(ch) (CH_BASE + ch * CH_SIZE + 0x002A)
/* MEMORY BUFFER ADDRESS /
//#define TX_BUF_ADDR 0x4000 //W5100 TX MEMORY BASE ADDRESS
//#define RX_BUF_ADDR 0x6000 //W5100 RX MEMORY BASE ADDRESS
/* MODE register values /
#define MR_RST 0x80 /< reset */
#define MR_PB 0x10 /< ping block */
#define MR_PPPOE 0x08 /< enable pppoe */
#define MR_LB 0x04 /< little or big endian selector in indirect mode */
#define MR_AI 0x02 /< auto-increment in indirect mode */
#define MR_IND 0x01 /< enable indirect mode */
/* Sn_MR MODE REGISTERS /
#define Sn_MR_CLOSE 0x00 /< unused socket */
#define Sn_MR_TCP 0x01 /< TCP */
#define Sn_MR_UDP 0x02 /< UDP */
#define Sn_MR_IPRAW 0x03 /< IP LAYER RAW SOCK */
#define Sn_MR_MACRAW 0x04 /< MAC LAYER RAW SOCK */
#define Sn_MR_PPPOE 0x05 /< PPPoE */
#define Sn_MR_ND 0x20 /< No Delayed Ack(TCP) flag */
#define Sn_MR_MULTI 0x80 /< support multicating */
/* Sn_CR COMMAND REGISTERS /
#define Sn_CR_OPEN 0x01 /< initialize or open socket */
#define Sn_CR_LISTEN 0x02 /< wait connection request in tcp mode(Server mode) */
#define Sn_CR_CONNECT 0x04 /< send connection request in tcp mode(Client mode) */
#define Sn_CR_DISCON 0x08 /< send closing reqeuset in tcp mode */
#define Sn_CR_CLOSE 0x10 /< close socket */
#define Sn_CR_SEND 0x20 /< updata txbuf pointer, send data */
#define Sn_CR_SEND_MAC 0x21 /< send data with MAC address, so without ARP process */
#define Sn_CR_SEND_KEEP 0x22 /< send keep alive message */
#define Sn_CR_RECV 0x40 /**< update rxbuf pointer, recv data */
/* Sn_SR SOCKET n STATUS REGISTER /
#define SOCK_CLOSED 0x00 //STATUS REGISTER FOR SOCK CLOSED
#define SOCK_INIT 0x13 //STATUS REGISTER FOR SOCKET INITIALISATION
#define SOCK_LISTEN 0x14 //STATUS REGISTER FOR SOCKET LISTEN
#define SOCK_ESTABLISHED 0x17 //STATUS REGISTER FOR SOCKET ESTABLISHMENT
#define SOCK_CLOSE_WAIT 0x1C //STATUS REGISTER FOR CLOSE WAITING
#define SOCK_UDP 0x22 //STATUS REGISTER FOR UDP
#define SOCK_IPRAW 0x32 //STATUS REGISTER FOR IPRAW
#define SOCK_MACRAW 0x42 //STATUS REGISTER FOR MACRAW
#define SOCK_PPPOE 0x5F //STATUS REGISTER FOR PPPOE
#define SOCK_SYNSENT 0x15 //STATUS REGISTER FOR SYNSENT
#define SOCK_SYNRECV 0x16 //STATUS REGISTER FOR SYNRECV
#define SOCK_FIN_WAIT 0x18 //STATUS REGISTER FOR FINISH WAIT
#define SOCK_CLOSING 0x1A //STATUS REGISTER FOR CLOSING
#define SOCK_TIME_WAIT 0x1B //STATUS FOR TIME WAIT
#define SOCK_LAST_ACK 0x1D //STATUS REGISTER FOR LAST ACKNOWLEDGEMWNT
#define SOCK_ARP 0x01 //STATUS REGISTER FOR ARP
/* IP PROTOCOL /
#define IPPROTO_IP 0 /< Dummy for IP */
#define IPPROTO_ICMP 1 /< Control message protocol */
#define IPPROTO_IGMP 2 /< Internet group management protocol */
#define IPPROTO_GGP 3 /< Gateway^2 (deprecated) */
#define IPPROTO_TCP 6 /< TCP */
#define IPPROTO_PUP 12 /< PUP */
#define IPPROTO_UDP 17 /< UDP */
#define IPPROTO_IDP 22 /< XNS idp */
#define IPPROTO_ND 77 /< UNOFFICIAL net disk protocol */
#define IPPROTO_RAW 255 /< Raw IP packet */
/* Sn_IR INTERRUPT REGISTER /
#define IR_CON 0x01 //INTERRUPT REGISTER FOR CONNECTION
#define IR_DISCON 0x02 //INTERRUPT REGISTER FOR DISCONNECT
#define IR_RECV 0x04 //INTERRUPT REGISTER FOR RECIEVE
#define IR_TIMEOUT 0x08 //INTERRUPT REGISTER FOR TIMEOUT
#define IR_SEND_OK 0x10 //INTERRUPT REGISTER FOR SEND_OK
The above code shows that how i defined all the registers of w5100.
Plaese check it if any wrong i have done and make it correct.
Thank you
