I’m currently using a wiz850io module with WIZNET5K drivers and I need to force such board to 10mbit. I know it’s possible via a sw configuration: do you have a quick hint to the right setting in the source code ?
Tnx
Tnx
Dear scardig!
You can refer to PHYCFGR register described in W5500 datasheet.
And, If you use ioLibrary, you can just ctlwizchip() function with “CW_SET_PHYCONF”.
As below is an example.
wiz_PhyConf myphyconf;
myphyconf.by = PHY_CONFBY_SW;
myphyconf.mode = PHY_MODE_MANUAL;
myphyconf.speed = PHY_SPEED_10M;
myphyconf.duplex = PHY_DUPLEX_HALF; // or PHY_DUPLEX_FULL
ctlwizchip(CW_SET_PHYCONF, (void*)&myphyconf);
you can download ioLibarary in github.
thx.
myphyconf.speed should be PHY_SPEED_10 without the final M
myphyconf.speed = PHY_SPEED_10;
Tnx
