Good day,
I was hoping someone could possibly assist me.
we have about 200 w5500 running as Servers which all work very well.
however we have recently received a project that requires us to use the W5500 as a client and a server talking to one another vs just a server.
attempting to connect after creating a socket completely hangs up the unit.
if((ret = connect(SOCK_ID_TCP,__au8_DesIp,0x1E61)) == SOCK_OK);
the problem appears to be with (getSn_IR(sn), creating an infinite loop.
while(getSn_SR(sn) != SOCK_ESTABLISHED) // not here
if (getSn_IR(sn) & Sn_IR_TIMEOUT) // this is where the infinite loop is created.
setSn_IR(sn, Sn_IR_TIMEOUT);
return SOCKERR_TIMEOUT;
please see below procedure -
int8_t connect(uint8_t sn, uint8_t * addr, uint16_t port)
uint32_t taddr;
CHECK_SOCKNUM();
CHECK_SOCKMODE(Sn_MR_TCP);
CHECK_SOCKINIT();
taddr = ((uint32_t)addr[0] & 0x000000FF);
taddr = (taddr << 8) + ((uint32_t)addr[1] & 0x000000FF);
taddr = (taddr << 8) + ((uint32_t)addr[2] & 0x000000FF);
taddr = (taddr << 8) + ((uint32_t)addr[0] & 0x000000FF);
if( taddr == 0xFFFFFFFF || taddr == 0)
return SOCKERR_IPINVALID;
if(port == 0)
return SOCKERR_PORTZERO;
setSn_DIPR(sn,addr);
setSn_DPORT(sn,port);
setSn_CR(sn,Sn_CR_CONNECT);
while(getSn_CR(sn));
if(sock_io_mode & (1<<sn))
return SOCK_BUSY;
return SOCK_OK;
please see below for full execution
#include "Wizchip_Conf.h"
#include “W5500.h”
#include “Socket.h”
sfr sbit Wizchip_Rst at GPIOC_ODR.B13;
sfr sbit Wizchip_CS at GPIOA_ODR.B4;
#define SOCK_ID_TCP 0
#define SOCK_ID_UDP 1
#define PORT_TCP_LOCAL 6000
#define PORT_TCP_REMOTE 6001
#define PORT_UDP 10001
#define DATA_BUF_SIZE 2048
char UartDebug;
char bufferDebug[2048];
int D,I;
unsigned short ReceivedDebug = 0,triggerTCP =0;
uint8_t gDATABUF[DATA_BUF_SIZE];
uint8_t __au8_DesIp[4] = {192, 168, 0, 40};
volatile wiz_NetInfo gWIZNETINFO =
{0x00, 0x14, 0xA3, 0x72, 0x17, 0x3f}, // Source Mac Address
{192, 168, 0, 177}, // Source IP Address
{255, 255, 255, 0}, // Subnet Mask
{192, 168, 0, 215}, // Gateway IP Address
{192, 168, 0, 215}, // DNS server IP Address
NETINFO_STATIC
volatile wiz_PhyConf phyConf =
PHY_CONFBY_HW, // PHY_CONFBY_SW
PHY_MODE_AUTONEGO, // PHY_MODE_AUTONEGO
PHY_SPEED_100, // PHY_SPEED_100
PHY_DUPLEX_FULL, // PHY_DUPLEX_HALF
volatile wiz_NetInfo pnetinfo;
// brief Call back function for WIZCHIP select.
void CB_ChipSelect(void)
Wizchip_CS = 0;
// brief Call back function for WIZCHIP deselect.
void CB_ChipDeselect(void)
Wizchip_CS = 1;
// brief Callback function to read byte usig SPI.
uint8_t CB_SpiRead(void)
return SPI_Read(0xAA);
// brief Callback function to write byte usig SPI.
void CB_SpiWrite(uint8_t wb)
SPI_Write(wb);
static void W5500_Init(void)
// Set Tx and Rx buffer size to 2KB
uint8_t buffsize[8] = { 2, 2, 2, 2, 2, 2, 2, 2 };
uint8_t sn2;
int32_t ret;
uint16_t size = 0, sentsize = 0;
int BufferSize =0;
GPIO_Digital_Output(&GPIOC_ODR, _GPIO_PINMASK_13); // Set Rst pin to be output
GPIO_Digital_Output(&GPIOA_ODR, _GPIO_PINMASK_4); // Set CS pin to be output
CB_ChipDeselect(); // Deselect module
// Reset module
Delay_ms(10);
Wizchip_Rst = 0;
Delay_ms(10);
Wizchip_Rst = 1;
Delay_ms(10);
SPI1_Init_Advanced(_SPI_FPCLK_DIV4, _SPI_MASTER | _SPI_8_BIT |
_SPI_CLK_IDLE_LOW | _SPI_FIRST_CLK_EDGE_TRANSITION |
_SPI_MSB_FIRST | _SPI_SS_DISABLE | _SPI_SSM_ENABLE | _SPI_SSI_1,
&_GPIO_MODULE_SPI1_PA567);
// Wizchip initialize
wizchip_init(buffsize, buffsize, 0, 0, CB_ChipSelect, CB_ChipDeselect, 0, 0, CB_SpiRead, CB_SpiWrite);
// Wizchip netconf
ctlnetwork(CN_SET_NETINFO, (void*) &gWIZNETINFO);
ctlwizchip(CW_SET_PHYCONF, (void*) &phyConf);
void TCP_Client(void)
int32_t ret;
int BufferSize =0;
UART3_Write_Text(“TCP Client Started !!!\n\r”);
if((ret = socket(SOCK_ID_TCP, Sn_MR_TCP, PORT_TCP_LOCAL, 0x00)) == SOCK_ID_TCP)
UART3_Write_Text(“created socket !!!\n\r”);
delay_ms(800);
if((ret = connect(SOCK_ID_TCP,__au8_DesIp,0x1E61)) == SOCK_OK){
UART3_Write_Text(“SOCKET connected\r\n”);
wireshark responds with
Frame 29080: 54 bytes on wire (432 bits), 54 bytes captured (432 bits) on interface 0
Ethernet II, Src: IntelCor_6f:28:31 (34:41:5d:6f:28:31), Dst: VitelecB_72:17:3f (00:14:a3:72:17:3f)
Internet Protocol Version 4, Src: 192.168.0.40, Dst: 192.168.0.177
Transmission Control Protocol, Src Port: 7777, Dst Port: 6000, Seq: 1, Ack: 1, Len: 0
Source Port: 7777
Destination Port: 6000
[Stream index: 1539]
[TCP Segment Len: 0]
Sequence number: 1 (relative sequence number)
[Next sequence number: 1 (relative sequence number)]
Acknowledgment number: 1 (relative ack number)
0101 … = Header Length: 20 bytes (5)
Flags: 0x014 (RST, ACK)
Window size value: 0
[Calculated window size: 0]
[Window size scaling factor: -2 (no window scaling used)]
Checksum: 0xb499 [unverified]
[Checksum Status: Unverified]
Urgent pointer: 0
[SEQ/ACK analysis]
[This is an ACK to the segment in frame: 29079]
[The RTT to ACK the segment was: 0.000026000 seconds]
[iRTT: 0.000026000 seconds]
[Timestamps]
I have a lot tried to change the ports to multiple ports.
please advise should you require any further info or if you would like me to upload libraries
