Input voltage on IO pins of WizWiki-w7500 and other 7500X chips
This post was flagged by the community and is temporarily hidden.
Hi, YegorS.
I’m sorry to mislead you.
W7500x can accept both 3.3V and 5V. but if you use 5V level, you can’t use ADC.
So i recommend you would use 3.3V level.(Not recommend using Max voltage)
Web page`s information will be changed.
I could not understand your second question.
If you follow datasheet`s characteristic, all W7500X chips work same under same electrical condition.
Please ask again, if my answer is not sufficient.
ADC is not available even at 3.3v level.
