Not getting send interrupt
I have configured the W5100 to be used in SPI mode and interrupt mode.
I am able to connect to the W5100.
Send and receive data using Modpoll tool.
I have observed one issue though.
Even though I recieve an RECV interrupt I dont get an Send Ok interrupt.
But I get the necessary data on the Modpoll, but I dont recieve an send OK interrupt.
Are there any known issues with this?
Thanks!!
I wonder how to process send data and send command.
For completing to send data, Sn_IR_SEND_OK need to set.
In your send processing, Did you already clear Sn_IR_SEND_OK bit?
If possible, post your ISR routine, IR & Sn_ISR & IMR access function, and Send function codes.
Below is my send function, Most of my code is similar to the wiznet sample code except my application code:
uint16_t send(SOCKET s, const uint8_t* p_ucharDataBuf, uint16_t ushLen)
uint8_t ucharStatus=0;
uint16_t ushRet=0;
uint16_t ushFreeSize=0;
uint16_t ushtxrd_after_send;
uint16_t ushtxrd_before_send;
if (ushLen > getW5100_TxMAX(s))
    ushRet = getW5100_TxMAX(s); // check size not to exceed MAX size.
else
    ushRet = ushLen;
// if freebuf is available, start.
do
    ushFreeSize = getSn_TX_FSR(s);
    ucharStatus = read_wiznet_reg(Sn_SR(s));
    /* If client requested an disconnect */
    if(ucharStatus == SOCK_CLOSE_WAIT)
        ushRet = getSn_RX_RSR(m_structTCPData.m_ucharCurrentSocket);
        recv(m_structTCPData.m_ucharCurrentSocket, m_aucharTCPRxBuf, ushRet);
        disconnectSocket(m_structTCPData.m_ucharCurrentSocket);
        return 0;
    else if (ucharStatus != SOCK_ESTABLISHED)
        ushRet = 0;
        break;
} while (ushFreeSize < ushRet);
// copy data
send_data_processing(s, (uint8_t *)p_ucharDataBuf, ushRet);
ushtxrd_before_send = read_wiznet_reg(Sn_TX_RD0(s));
ushtxrd_before_send = (ushtxrd_before_send << 8) + read_wiznet_reg(Sn_TX_RD0(s) + 1);
/* Issue the SEND command */
write_wiznet_reg(Sn_CR(s),Sn_CR_SEND);
Delay_ms(1);
/* wait to process the command... */
while( read_wiznet_reg(Sn_CR(s)) );
/* while ( (read_wiznet_reg(Sn_IR(s)) & Sn_IR_SEND_OK) != Sn_IR_SEND_OK )
if ( read_wiznet_reg(Sn_SR(s)) == SOCK_CLOSED )
close(s);
return 0;
//write_wiznet_reg(Sn_IR(s), Sn_IR_SEND_OK);
ushtxrd_after_send = read_wiznet_reg(Sn_TX_RD0(s));
ushtxrd_after_send = (ushtxrd_after_send << 8) + read_wiznet_reg(Sn_TX_RD0(s) + 1);
if(ushtxrd_after_send > ushtxrd_before_send)
    ushRet = ushtxrd_after_send - ushtxrd_before_send;
else
ushRet = (0xffff - ushtxrd_before_send) + ushtxrd_after_send + 1;
return ushRet;
My ISR processing function is below. This function is called from an ISR, it saves the interrupt type, clears the wiznet interrupt and sets an TCP_FLAG.
void processWiznetISR(void)
uint8_t ucharIRvalue;
uint8_t ucharSNIRvalue;
//uint8_t ucharIRvalue = getSn_IR(SOCKET_0);
    ucharIRvalue = getIR();
  /* process all interrupts */
  do
      if (ucharIRvalue & IR_CONFLICT)
          /*IP conflict */
          write_wiznet_reg(W5100_IR, 0xf0);           /* clear interrupt */
      if (ucharIRvalue & IR_UNREACH)
          /*INT Port Unreachable */
      if (ucharIRvalue & IR_SOCK(SOCKET_0))
          /* save interrupt value*/
          I_STATUS[SOCKET_0] |= read_wiznet_reg(Sn_IR(SOCKET_0)); // can be come to over two times.
          //processSocketCommand();
          write_wiznet_reg(Sn_IR(SOCKET_0), I_STATUS[SOCKET_0]);
          /* Clear the interrupt */
          //write_wiznet_reg(Sn_IR(SOCKET_0), 0xFF);
    if (ucharIRvalue & IR_SOCK(1))
        I_STATUS[1] |= read_wiznet_reg(Sn_IR(1));
        write_wiznet_reg(Sn_IR(1), I_STATUS[1]);
    if (ucharIRvalue & IR_SOCK(2))
        I_STATUS[2] |= read_wiznet_reg(Sn_IR(2));
        write_wiznet_reg(Sn_IR(2), I_STATUS[2]);
    if (ucharIRvalue & IR_SOCK(3))
        I_STATUS[3] |= read_wiznet_reg(Sn_IR(3));
        write_wiznet_reg(Sn_IR(3), I_STATUS[3]);
    /* re-read interrupt value*/
    ucharIRvalue = read_wiznet_reg(W5100_IR);
}while (ucharIRvalue != 0x00);           /* if exist, contiue to process */
TCP_FLAG = TRUE;
// write_wiznet_reg(Sn_IR(m_structTCPData.m_ucharCurrentSocket), 0xFF);
ucharSNIRvalue = getSn_IR(0);
And below is my interrupt processing functions:
void processSocketCommand(void)
if(TCP_FLAG == TRUE)
if (I_STATUS[SOCKET_0] != 0)
m_structTCPData.m_ucharCurrentSocket = SOCKET_0;
processTcpCommand(I_STATUS[SOCKET_0]);
//write_wiznet_reg(Sn_IR(0), I_STATUS[0]);
I_STATUS[SOCKET_0] = 0;
if (I_STATUS[SOCKET_1] != 0)
m_structTCPData.m_ucharCurrentSocket = SOCKET_1;
processTcpCommand(I_STATUS[SOCKET_1]);
I_STATUS[SOCKET_1] = 0;
if (I_STATUS[SOCKET_2] != 0)
m_structTCPData.m_ucharCurrentSocket = SOCKET_2;
processTcpCommand(I_STATUS[SOCKET_2]);
I_STATUS[SOCKET_2] = 0;
if (I_STATUS[SOCKET_3] != 0)
m_structTCPData.m_ucharCurrentSocket = SOCKET_3;
processTcpCommand(I_STATUS[SOCKET_3]);
I_STATUS[SOCKET_3] = 0;
/* Clear the TCP_FLAG since all the interrupts have been processed /
TCP_FLAG = FALSE;
//write_wiznet_reg(Sn_IR(m_structTCPData.m_ucharCurrentSocket), 0xFF);
void processTcpCommand(uint8_t ucharSn_IR)
uint16_t ushlen = 3;
uint8_t status = 0x01;
ucharValue = getSn_SR(m_structTCPData.m_ucharCurrentSocket);
switch(ucharSn_IR)
    case Sn_IR_RECV:
        temp = 0;
        m_structTCPData.m_ucharBytesReceived = getSn_RX_RSR(m_structTCPData.m_ucharCurrentSocket);
        m_structTCPData.m_pucharRxDataLoc = m_aucharTCPRxBuf;
        /* Check if data is received */
        if (m_structTCPData.m_ucharBytesReceived > 0)
            ushlen = recv(m_structTCPData.m_ucharCurrentSocket, m_aucharTCPRxBuf, m_structTCPData.m_ucharBytesReceived);
        while(m_structTCPData.m_ucharBytesReceived > 0) // check the size of received data
            //ushlen = recv(m_structTCPData.m_ucharCurrentSocket, m_structTCPData.m_ucharTCPHeader, TCP_MODBUS_HEADER_LENGTH);
            /* Read the first 6 bytes of the frame */
            moveTCPRxData(m_structTCPData.m_pucharRxDataLoc,  m_structTCPData.m_ucharTCPHeader, TCP_MODBUS_HEADER_LENGTH);
            m_structTCPData.m_ucharBytesReceived -= TCP_MODBUS_HEADER_LENGTH;
            checkTCPProto();
        break;
    case Sn_IR_SEND_OK:
        /* The send operation was sucessfull
         * I dont know what to do next
        break;
    case Sn_IR_TIMEOUT:
        disconnect(m_structTCPData.m_ucharCurrentSocket);
        socket(m_structTCPData.m_ucharCurrentSocket, Sn_MR_TCP, 502, 0);    // open the SOCKET
        status = listen(0);
        break;
    case Sn_IR_DISCON:
         temp = 1;
         if(m_structTCPData.m_ucharBytesReceived > 0) // check the size of received data
        status = listen(0);
        break;
    case Sn_IR_CON:
        /* Connection has been establised
        //send(m_structTCPData.m_ucharCurrentSocket ,buf, ushlen);
        m_structTCPData.m_ushLastSeqNo = 0;
        m_structTCPData.m_ucharStartFlag = FALSE;
        break;
    default:
        break;
Most above all, check sending packet is completed.
I want to know just send interrupt doesn’t occur or send procedure is not working.
Best regards.
The send procedure is working.
When a send a modbus query via Modpoll I recieve the necessary response back.
The only issue here is I dont get an send complete interrupt.
I get the recieve interrupt .
The other issue is I dont get the disconnect interrupt also. I get that interrupt after quiet some time.
But I dont want to tackle that issue right now, since first I want to resolve the send interrupt issue first.
Thanks!!!
Your code seem to have no problem.
Did you modus TCP/IP using modpoll program.?
And when do you call send()? Can you post the code of call send()?
In send(), why don’t you wait until Sn_IR_SENDOK = 1?
For completing to send data, it need to one send command and one Sendok ISR.
If you not check Sendok ISr after send command, next send command can’t work well.
