Se puede conectar via Telnet?
Existe algun firmware que se deba cargar para hacer posible conexion Telnet?
Ademas cuando conecto el programa la ‘OPCIONs’ Telnet (RF2217) no se puede seleccionar.
Es posible en los modulos WIZ750SR o WIZ752 tengan TELNET?
Can you connect via Telnet?
Is there any firmware that must be loaded to make possible a Telnet connection?
Also when I connect the program the ‘OPTIONS’ Telnet (RF2217) cannot be selected.
Is it possible for modules WIZ750SR or WIZ752 to have TELNET?
The question is for the following:
Already connected in a network, they are programmed with the soft “tool 1.4.4.1”
. But the following happens:
it is given a RESET (remotely in a network) and from that moment the “toolxx” program no longer sees it. The connection made by RS232 is lost (configured).
If you ping him with CMD you see the team.
But never again how can you enter through the configuration program (Tool xxx) …
And since Telnet cannot be done, a big problem is generated
I’m sorry we could’t support what you want.
Could you please let me know the product full name?
The “tool 1.4.4.1” is for WIZ107sr or WIZ108sr.
If you use the WIZ750sr series, you must use the WIZnet S2E Configration Tool V1.1.0 as Configuration tool.
There are two methods the UDP broadcast and TCP unicast for product search method.
In your case I recommend you use TCP unicast method and you just enter your product IP and port.
The Wizconfig V1.1.0 tool can be compiled in PYQ5 as I understand.
Download all the files and try to generate a new .exe file.
I wanted to add some things. But it is not very clear to me if I only have to ask you to compile (genere.exe) only 1 file to the PYINSTALLE main_gui.py program (this one?) And call all the others .py to compile?
Python (pyinstaller) generates a main_gui.exe
but when you execute them you do nothing.
I see that I generate all the folders (attached folders) but it doesn’t work.
Any guide?
Thank you so much
I think old components are affected. (build directory)
And did you install required packages?
(When I tried to install pyqt5-5.9.2 with python 3.8.1, I got error.
So I installed latest pyqt5(pyqt5-5.14.1) for python 3.8.)
Please try to below.
Delete old directories (build, dist) and retry generate.
(If 1) is not work) Install the latest version packages and retry.
Before creating the exe file, first check whether the program is running using the command below.
