I’m new in the foro and i working on a few weeks with the W5100 module in a FRDM-KL46Z board. I’m programmer for a lot time ago, in C and C++ languages.
In this moment, the project that i working is about a Web Server for IoT device to control differents industrial process and log data.
The WebServer is all right but, when i need to log something, i need the date and time for correct data logging. So, i try to get the date and time from NTP protocols.
Ok, here is when the problems begans. I trying to make a client to connect with teh NTP servers, but when i make the data send to wait the answer from the server, the only menssage what i have is an ARP.
I make all the steps like the datsheet show and i check my code with Arduino examples or the other users make do, but i always have an ARP to the gateway. What can i do?
I’m using a static IP, because i don’t have programed the DHCP algorithm.
How i make that? I open the socket with the local port, then i put the destination port and destination IP, and send the message for the NTP solicitation. Finally, i close the socket.
With that, in the wireshark i can see the ARP with a broadcast, but nobody responds.
If you use a virtual ip without dhcp, you can’t send to packet external network.
Port forwarding be configured at the router.
Please find out how to set up your router.
