Hello.
Before any question excuse me for my English. My language isn’t English.
I want to write a simple test code for W5500 with Arduino Due. W5500 works as a client and
my PC works as a server. The code saves a character in TX buffer and sends it to my PC.
My code performs the following tasks:
loading common registers with appropriate values
opening the socket0 in TCP mode
connecting to server
until here all things are perfect, but when i run send command (Sn_CR=0x20), the server receives arbitrary bytes. I perform updating process of Sn_TX_WR with respect to data sheet.
Also, according to W5500 data sheet after connecting to server in TCP
mode, the value of Sn_TX_RD and Sn_TX_WR will be re-initialized to 0x0000.
But when i read these registers after connect command (Sn_CR=0x04), W5500 returns arbitrary numbers for both and these values are same for these registers. Also the value of Sn_TX_FSR
reads as 0X0800 which is correct.
When i read these registers after send command (Sn_CR=0x20), W5500 returns 0x0000 for
Sn_TX_WR and Sn_TX_RD and an arbitrary number for Sn_TX_FRS.
I don’t know where is the problem. Can anyone help me???
Thanks in advance.
The problem solved!
A little mistake in writing to tx buffer.
But i wondering why W5500 returns an arbitrary numbers for Sn_TX_RD and Sn_Tx_WR registers after connecting to server?
Server software on pc is a simple c code downloaded from internet and has been tested.
Thanks for your reply.
Hi, I have same problem now…!
When sending string to a server I get a lot of “garbage” with the string.
Reading getSn_TX_FSR before sending give 800h (2048) as expected but after sending the value is “strange” and not what I expect (2048 - string lengh)…
What was the writing mistake? can you share it?
Any Idea?
Dan Groswirth cellkey.tech.gmail.com
Hello e_sh:
Thanks for your response. The way you suggest to update pointer is not documented as far as I know. I have not seen it in any of the examples I have seen.
Dont understand the " (Sn_TX_RD0 & Sn_TX_RD1)" that you mentioned. I use Sn_Tx_WR to get the pointer to writing location, as done at the send() rutine in socket.c file.
Please explain your idea .
Thanks
Dan
hi
I wrote my code without any library hence i manipulate registers directly.
According to datasheet “Sn_TX_RD0 & Sn_TX_RD1” are high byte and low byte of pointer, respectively.
More details on what i do:
I read the registers 0x0022 and 0x0023 in socket register block. These registers indicate the start address for writing your data in TX buffer.
Then i saved my data (for testing purpose i saved chatacter ‘a’) in TX buffer at address “Sn_TX_RD”.
After these the Sn_TX_WR pointer must be updated as i mentioned in previous post.
finally i issued the send command.
what i discribed is mentioned in pages 54 and 55 of W5500 datasheet version1.0.9.
Following is the piece of code related to these steps:
Hello e_sh:
Thanks again for your support.
I am getting into your code in order to understand the lower level of the handling of the appropriate registers…
You read TX_RD to set the writing address while W5500 library show reading TX_WR
as in that code:
//writing data to TX buffer
void wiz_send_data(uint8_t sn, uint8_t *wizdata, uint16_t len)
uint16_t ptr = 0;
uint32_t addrsel = 0;
if(len == 0) return;
ptr = getSn_TX_WR(sn); //<<<<<<setting the pointer
ptr += len;
setSn_TX_WR(sn,ptr);
I still confused about handling the TX_WR and TX_RD pointers as I have problem
that data I send is seen on server wrapped by “endless” garbage bytes and written several times…
Regards
Dan
Hi Dan1.
Yes. The code is written for W5500.
According to description of Sn_TX_RD in datasheet (page 54):
SEND command transmits the saved data from the current Sn_TX_RD to the Sn_TX_WR in the socket n TX buffer. After transmitting the saved data, the SEND command increases the Sn_TX_RD as same as the Sn_TX_WR.
Hence, i think in the “wiz_send_data” routine, at line :
the Sn_TX_RD and Sn_TX_WR registers have the same value.
Are you sure about your code on server side?
