I am currently trying to get a data from a serial device using my WIZ1000 and I am using the virtual com port created by WIZ VSP. I am using LabVIEW for the programming and I can’t seem to get any data coming from my serial device. I used VISA functions to read any data in the virtual port created.
Should I used TCP functions instead? And if I do, should I use the default IP Address and Port from the WIZ1000 Configuration tool?
Do you have any code examples for scenarios like this? Any programming language can help.
Thank you!
Here is my setup:
RS232 Device ----> GIVEN RS2323 CABLE -----> WIZ1000 ------> GIVEN ETHERNET CABLE ------> ROUTER ------> STRAIGHT THROUGH ETHERNET CABLE -----> LAPTOP
