http://wizwiki.net/wiki/doku.php?id=products:w5500:refschematic
for the above Link RJ45 with Integrated Transformer TYPE W5500 design BOM is not provided for better design it is needed. Pls help with BOM
Dear @Vpan
You don’t have to use the same Transformers.
You can use a similar spec and an easy-to-get transformer.
It is not of RJ-45 Connector but some caps i have doubt. BOM will clear some issues then i will choose my own components as per that
