I have problem regarding read data from GPIO Wizfi 220, My finals goal just want to sent data from Chipcap-D/Module Sensor [url]http://www.icbanq.com/shop/product_detail.asp?prod_code=P000820080[/url] to Wizfi 220 EVB device. From chipcap-D sensor datasheet [url]http://data.icbank.com/ICBShop/board/CHIPCAP-D%20module%20설명자료1.pdf[/url] to get data I need to do simple calculation. So my question, what kind of microcontroller or microprocessor are using in wizfi 220? How to put or load c code into Wizfi 220 EVB? What kind of program or software that I can used to load my code to Wizfi? or Is it possible to received and calculate data digital from sensor in at-command mode?
[quote]WizFi210 used ARM7 core. But you can’t program to it. You have to use serial or SPI interface in order to control WizFi210.
[/quote]
But WizFi210 can control GPIO(GPIO19,GPIO20) pin through AT+DGPIO of AT Command.
For example, If you enter AT+DGPIO=19,0, WizFi210 will be changed to LOW to GPIO 19.
For more information, Refer to WizFi210 Programers Guide.
[quote]But WizFi210 can control GPIO(GPIO19,GPIO20) pin through AT+DGPIO of AT Command.
For more information, Refer to WizFi210 Programers Guide.[/quote]
Do you mean that I’m only can control “ON” or “OFF” condition in GPIO?
In other, I found in Pin Map description Wizfi 220 have ADC1 (12) and ADC2 (13), Are there any idea how to access this port?
I have experience using AVR Atmega 128, so I just assumpt we can program Wizfi 220 port like what I did in AVR.
but now I have another question, because I can’t modified the wizfi 220 code as your describe before I try to connect the wizfi 220 with ATmega 128 microcontroller (uC) using UART serial port (Tx and Rx), but I have some problem I could know my data is sent or not from uC to wizfi? Do you have any suggestion or document so that I refer to solve this kind of problem?
If WizFi220 received serial data successfully, WizFi220 will return same data. Because WizFi220 is set echo mode.
So you can check using this echo data.
And If WizFi220 received serial command successfully such as AT, WizFi220 will return [OK] message.
[quote]If WizFi220 received serial data successfully, WizFi220 will return same data. Because WizFi220 is set echo mode.
And If WizFi220 received serial command successfully such as AT, WizFi220 will return [OK] message.[/quote]
hi Kaizen,
Now I try to send [AT] command using docklight [url]http://www.docklight.de/[/url] but the reply message is also [AT] not [OK] like your explain before, I think there are some problem here.
Now using hyperterminal AT command working well, but I have another problem regarding save the profile I have made. first I already setting static IP in wizfi using Wizsmartscript 192.168.0.111, but everytime I turn off the wizfi 220 and turn on again the IP address change again to 0.0.0.0.
Do you have any idea about how to save and keep the ip of wizfi always static even I turn of and turn on again the device?
