About the resistance of RSET_BG
Hi.
I’m evaluating a pcb board with W5300 chip.
What is the function of the pull-down resistor of RSET_BG?
What happens if it is not 12.3kΩ?
You must use 12.3 k.
The resistor is not a pull-down.
A resistor that limits the current of a chip’s internal element.
Thank you
Thank you for reply.
If the resistor value is not 12.3k, will the chip fail?
