Hello everyone, have a good day, I’m new to the forum. I am working on some projects to develop smart home systems with arduino. I use Arduino uno, ethernet shield and teleduino structures in it. but i am having a problem with the wiznet w5100 device. I use vdsl modem (VMG3312-B10B) and switch (EP-808SX-C) devices at home. I program the arduino device with the teleduino sample code and start the testing process. I do the test operations through teleduino api.
everything works properly when I connect modem <-> ethernet <-> w5100. but when i connect with modem <-> ethernet <-> switch <-> ethernet <-> w5100, i can’t access teleduino api.
It seems that the assignment of the ip is done on the main page of the modem, but this screen is only visible when a direct connection between the modem and the w5100 is provided. I send a ping through windows cmd and everything looks fine.
however, when I connect the w5100 device with a switch, the connection information on the modem interface is lost.
my source codes:
Teleduino328EthernetClientProxy.ino - Teleduino328EthernetClientProxy example
Version 328-0.6.9
Nathan Kennedy 2009 - 2014
http://www.teleduino.org
This sketch is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#include <EEPROM.h>
#include <Servo.h>
#include <Wire.h>
#include <Teleduino328.h>
#include <SPI.h>
#include <Ethernet.h>
// User configurable variables
byte useDhcp = true;
byte useDns = true;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress deviceIp(192, 168, 1, 57); // Only if useDhcp is false
IPAddress gatewayIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress dnsIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress subnet(255, 255, 255, 0); // Only if useDhcp is false
IPAddress serverIp(173, 230, 152, 173); // Only if useDns is false
char serverName[] = "us01.proxy.teleduino.org"; // Only if useDns is true
unsigned int serverPort = 5353; // Can be set to either 53 or 5353
byte statusLedPin = 8;
// User configurable key, this is used to authenticate with the proxy server
// This is checked against the EEPROM on boot and written if necessary
// The proxy server retreives the key from the EEPROM
byte key[] = { 0xE3, 0x11, 0xD2, 0x41,
0xE6, 0x5F, 0x6D, 0x6C,
0x5B, 0x7A, 0x7C, 0x79,
0xEB, 0x10, 0x64, 0xDE };
// E311D241E65F6D6C5B7A7C79EB1064DE -> API KEY
// Other required variables
byte data[257];
byte dataLength;
byte hexStage;
unsigned long lastInstruction = 0;
unsigned long lastRefresh = 0;
byte stage = 0;
// Declare client object
EthernetClient Client;
void setup()
// Load presets
Teleduino328.loadPresets();
// Set status LED pin
Teleduino328.setStatusLedPin(statusLedPin);
Teleduino328.setStatusLed(1); // Initialisation
// Check the EEPROM header and check to see if the key is correct
// This is to ensure the key is not cleared from the EEPROM
if(EEPROM.read(0) != '#')
EEPROM.write(0, '#');
if(EEPROM.read(1) != 0)
EEPROM.write(1, 0);
if(EEPROM.read(2) != '#')
EEPROM.write(2, '#');
if(EEPROM.read(160) != '#')
EEPROM.write(160, '#');
for(byte i = 0; i < 16; i++)
if(EEPROM.read(161 + i) != key[i])
EEPROM.write(161 + i, key[i]);
if(EEPROM.read(177) != '#')
EEPROM.write(177, '#');
// Start network and attempt to connect to proxy server
Teleduino328.setStatusLed(2); // Network configuration
if(useDhcp)
if(!Ethernet.begin(mac))
Teleduino328.setStatusLed(2, false, 10000);
Teleduino328.reset();
else
Ethernet.begin(mac, deviceIp, dnsIp, gatewayIp, subnet);
delay(1000);
Teleduino328.setStatusLed(3); // Connect to server
if((useDns && !Client.connect(serverName, serverPort)) || (!useDns && !Client.connect(serverIp, serverPort)))
Teleduino328.setStatusLed(3, false, 10000);
lastInstruction = millis();
void loop()
if(Client.connected())
// What we need to do depends on which 'stage' we are at
switch(stage)
case 0: // Wait for start byte
if(Client.available())
char c = Client.read();
if(c == '?')
stage++;
break;
case 1: // Reset variables
dataLength = 0;
hexStage = 0;
stage++;
break;
case 2: // Instruction byte
if(c == '?')
stage = 1;
break;
else if(c == '\r' || c == '\n' || c == '.')
stage = 0;
break;
if(!hexStage)
data[0] = Teleduino328.hexDecode(c) * 16;
else
data[0] += Teleduino328.hexDecode(c);
hexStage = !hexStage;
if(!hexStage)
stage++;
break;
case 3: // Data length byte
if(c == '?')
stage = 1;
break;
stage = 0;
break;
if(!hexStage)
data[1] = Teleduino328.hexDecode(c) * 16;
else
data[1] += Teleduino328.hexDecode(c);
if(!hexStage)
stage++;
break;
case 4: // Data
if(c == '?')
stage = 1;
break;
if(dataLength == data[1])
stage++;
break;
else
stage = 0;
break;
if(!hexStage)
data[2 + dataLength] = Teleduino328.hexDecode(c) * 16;
else
data[2 + dataLength] += Teleduino328.hexDecode(c);
if(!hexStage)
dataLength++;
break;
case 5: // Execute instruction and return result
Teleduino328.instruction(data);
Client.write('!');
for(int i = 0; i < data[1] + 2; i++)
Client.write(Teleduino328.hexEncode(data[i] / 16));
Client.write(Teleduino328.hexEncode(data[i] % 16));
Client.write('\n');
stage = 0;
break;
else
Teleduino328.setStatusLed(10);
// Has the instruction timeout been reached?
if(millis() - lastInstruction > 30000)
Client.flush();
Client.stop();
Teleduino328.setStatusLed(9);
// Process refreshes every 50ms
if(millis() - lastRefresh >= 50)
Teleduino328.pinTimers();
Teleduino328.shiftRegisterTimers();
Teleduino328.shiftRegisters();
lastRefresh = millis();
// Check to see if reset has been requested
Teleduino328.checkReset();
So as a result, I cannot use the w5100 with a switch. How should I proceed to solve this problem? Thank you.
