So i’ll try to explain my environment as simple as possible.
I want to be able to access my wizfi210 from anywhere on the web. Once connected, i want to send data from whatever internet connected device i’m at, to my arduino UNO. Having trouble getting started, any help is appericated.
[quote]I want to be able to access my wizfi210 from anywhere on the web. Once connected, i want to send data from whatever internet connected device i’m at, to my arduino UNO. Having trouble getting started, any help is appericated.[/quote] My opinion for access your wizfi you need to make your wizfi as the client in router after that you just forward one port in your router for example your wizfi have the local ip 192.168.1.10 and you router public ip 15.17.1.24, So in router you need to make rule to forward public ip to direct go to your local ip than you can access your device from anywhere as long as you have internet connection.
Regards,
Danil
