I start working on a w5500 chip, and I have two problems.
I want to use it in TCP mode to connect server IP and Port and send data to it.
the first problem is that some times it didn’t start connecting and sending data until I ping W5500 IP in server Command prompt! after that, it starts sending data.
another problem is that it stops sending data after 5-6 minutes! So I should restart it again to send data.
Plus it gets really hot, is it normal?
best regards,
