My application require power over Ethernet. Can you give a link with rj45 jack datasheet?
Is it possible with this jack to use pins 4,5,7,8 for POE?
RJ45 for wiz550io
Company : CETUS
Part No : J1B1211CCD
Data sheet will be posted.
The attached file is J1B121ZCCD.
Internal circuit of J1B121ZCCD is same with J1B1211CCD.
and It doesn’t support PoE.
J1B121ZCCD-V0-101115.pdf (149 KB)
