Hello all:
I am having strange fenomena in which when sending a string to the sever by W5500 , wireshark shows endless incoming chars long befor the sent string is shown as well . String of 10 bytes make the server to get thousends! of “garbage” bytes around it…
Setup seems to be ok and I got stucked…
Good idea will be appreciated…
Dan
Hello, I just encounter the same issue. You need to read the tx_wr-Pointer just before sending.
…Hi, problem solved long ago. Board works as expected, and even beyond…
