The remote host application I am using for the WizNet 750SR sends out a UDP broadcast packet 255.255.255.255:5280. The host IP is 192.168.099:HostPort#. The Wiz750 replies to 192.168.099:Remote Port#. The host IP is what is set up by the Host computer ( Windows 10 → Network and Sharing Center->WizNet->Properties->Internet Protocol Version (TCP/IP4)
The problem is every time I launch the host application, it uses a different HostPort#, but WizNet will only respond to the Remote Port setting in the S2E configuration tool.
Is there someway to configure the Wiz750 to reply to the HostPort# in this situation?
Thanks in advance for your help
