WizFi210 Resets, Freezes
We are using WizFi210 firmware revision 1.1.0.5 multiple sockets,
CID 0 is UDP.
CID 1 is TCP listening.
CID 2 is TCP listening.
Receive [CONNECT 2 3 xxx.xxx.xxx.xxx xxxxx],
Receive a 60 byte packet on CID 3,
Transmit a 160 byte packet on CID 3,
Close CID 3,
Resumes listening.
This cycle occurs about once a second for 20-25 cycles.
Then we receive “APP Reset-APP SW Reset”, consistently,
or WizFi simply freezes and refuses to answer any command.
Occasionally we receive a memory dump, but very infrequently.
Any hints on what is happening and how we can solve this behaviour?
Thanks
Hi
If possible, Could you upgrade firmware to 1.1.1.0?
If this problem occur in latest firmware again, I will report it to our test team.
Firmware 1.1.1.0 behaves the same as 1.1.0.5.
We receive “APP Reset-Wlan Except” occasionally,
as well as “APP Reset-APP SW Reset”.
One or the other and WizFi is dead.
Hi
For testing your issue and finding solution, We need full log of which you used.
Could you let me know which command is used ?
Complete Log of the Crash and Freeze problem:
[UnExpected Warm Boot(Possibly Low Battery)]
[Error] or [Low Battery]!
Tx:ATC0
[OK]
Tx:AT
[OK]
Tx:AT+RESET
[ERROR: INVALID INPUT]
Tx:AT+XRESET
Tx:ATE0
[OK]
Tx:AT+NDHCP=0
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751475003
[OK]
Tx:AT+WD
[OK]
Tx:AT+WM=0
[OK]
Tx:ATC0
[OK]
Tx:AT+XEHT=2,1,0,3
[OK]
Tx:AT+XDUM=0
[OK]
Tx:AT+NMAC=?
40:d8:55:01:03:3a
[OK]
Tx:AT+NMAC2=?
40:d8:55:01:03:3a
[OK]
Tx:ATI0
WIZnet
[OK]
Tx:ATI1
GS1011
[OK]
Tx:ATI2
WizFi210
1.1.1.0(W)
[OK]
Tx:ATV1
[OK]
Tx:AT+PSPOLLINTRL=1
[OK]
Tx:AT+BATTLVLSET=2000,1,1800
[OK]
Tx:AT+BCHKSTRT=1
[OK]
Tx:AT+BATTVALGET
Battery Value:2.179 V
[OK]
Tx:AT+WS
BSSID SSID Channel Type RSSI Security
20:c9:d0:20:98:01, SSalinasWAP03 , 01, INFRA , -38 , WPA2-PERSONAL
20:c9:d0:1e:d6:51, SSalinasWAP01 , 01, INFRA , -38 , WPA2-PERSONAL
20:c9:d0:a1:40:4a, SSalinasWAP02 , 06, INFRA , -84 , WPA2-PERSONAL
c8:d7:19:43:cf:e7, SSalinasWAP04 , 11, INFRA , -20 , WPA2-PERSONAL
No.Of AP Found:4
[OK]
Tx:AT+WRSSI=?
0
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751477435
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751477460
[OK]
Tx:AT+WA=SSalinasWAP04
IP SubNet Gateway
192.168.1.254: 255.255.255.0: 192.168.1.1
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751480353
[OK]
Tx:AT&Y0
[OK]
Tx:AT&W0
[OK]
Tx:AT+NSTAT=?
MAC=40:d8:55:01:03:3a
WSTATE=CONNECTED MODE=AP
BSSID=c8:d7:19:43:cf:e7 SSID=“SSalinasWAP04” CHANNEL=11 SECURITY=WPA2-PERSONAL RSSI=-21
IP addr=192.168.1.254 SubNet=255.255.255.0 Gateway=192.168.1.1 DNS1=0.0.0.0 DNS2=0.0.0.0
RxCount=5 TxCount=54
[OK]
Tx:AT+CID=?
No valid Cids
[OK]
Tx:AT+WRSSI=?
-21
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751480585
[OK]
Tx:AT+NDHCP=1
IP SubNet Gateway
192.168.6.24: 255.255.255.0: 192.168.6.1
[OK]
Tx:AT+GETTIME=?
Current Time in msec since epoch=1374751483860
[OK]
DHCP Time(Sec)=3.275
Tx:AT&Y0
[OK]
Tx:AT&W0
[OK]
Tx:AT+NSTAT=?
BSSID=c8:d7:19:43:cf:e7 SSID=“SSalinasWAP04” CHANNEL=11 SECURITY=WPA2-PERSONAL RSSI=-19
IP addr=192.168.6.24 SubNet=255.255.255.0 Gateway=192.168.6.1 DNS1=192.168.6.1 DNS2=0.0.0.0
RxCount=15 TxCount=110
[OK]
Tx:AT+CID=?
No valid Cids
[OK]
Tx:AT+WRSSI=?
-20
[OK]
Tx:AT+NSUDP=10004
[CONNECT 0]
[OK]
Tx:AT+CID=?
CID TYPE MODE LOCAL PORT REMOTE PORT REMOTE IP
0 UDP SERVER 10004 0 0. 0. 0. 0
[OK]
Tx:AT+NSTCP=40404
[CONNECT 1]
[OK]
Tx:AT+CID=?
1 TCP SERVER 40404 0 0. 0. 0. 0
[OK]
Tx:AT+NSTCP=30998
[CONNECT 2]
[OK]
Tx:AT+CID=?
2 TCP SERVER 30998 0 0. 0. 0. 0
[OK]
Tx:AT+CID=?
[OK]
Tx:AT+CID=?
[OK]
Tx:{Esc}U0255.255.255.255:10004:runt{Esc}E
Rx:[CONNECT 2 3 192.168.6.15 59535]
Tx:AT+CID=?
3 TCP CLIENT 30998 59535 192.168. 6. 15
[OK]
Rx:[DISCONNECT 3]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59536]
Tx:AT+CID=?
Rx:{Esc}S3GET /axis-cgi/io/input.cgi?checkactive=1,2,3,4,5,6,7,8 HTTP/1.1
Host: 192.168.6.24
Connection: Keep-Alive
{Esc}ECID TYPE MODE LOCAL PORT REMOTE PORT REMOTE IP
3 TCP CLIENT 30998 59536 192.168. 6. 15
[OK]
Tx:{Esc}S3HTTP/1.0 200 OK
Content-Type: text/plain
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59537]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59537 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59538]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59538 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59539]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59539 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59540]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59540 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59541]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59541 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59542]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59542 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59543]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59543 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59544]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59544 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59545]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59545 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59546]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59546 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59547]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59547 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59548]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59548 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59549]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59549 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59550]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59550 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59551]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59551 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59552]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59552 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59553]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59553 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59554]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59554 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59555]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59555 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59556]
Tx:AT+CID=?
Host: 192.168.6.24
3 TCP CLIENT 30998 59556 192.168. 6. 15
[OK]
input1=inactive
input2=inactive
input3=inactive
input4=inactive
input5=inactive
input6=inactive
input7=inactive
input8=inactive
{Esc}E
Tx:AT+NCLOSE=3
[OK]
Tx:AT+CID=?
[OK]
Rx:[CONNECT 2 3 192.168.6.15 59557]
Tx:AT+CID=?
Rx:APP Reset-Wlan Except
Hi
I did send reference to your e-mail for solving this problem.
Please check your e-mail.
Dear Support
Did this fix the problem?
I am also troubled by the nearly problem.
Please tell me.
Thanks
Hello
I just attached WizFi210 1.2.0.6 enterprise f/w version.
Please try it with this version.
