Hi.
I’m working on app, which utilizes SPI in DMA mode for communication between STM32F030K6 and Wiz850. I have registered the following functions:
reg_wizchip_cs_cbfunc(SPI_Soft_nSS_On, SPI_Soft_nSS_Off);
reg_wizchip_spiburst_cbfunc( SPI_DMA_Rx_Burst, SPI_DMA_Tx_Burst);
Program works fine till the moment I try to use wizchip_getnetinfo() function. For some reason it calls WIZCHIP_READ function (what I believe it shouldn’t do if I registered SPI burst functions).
uint8_t WIZCHIP_READ(uint32_t AddrSel)
uint8_t ret;
uint8_t spi_data[3];
WIZCHIP_CRITICAL_ENTER();
WIZCHIP.CS._select();
AddrSel |= (W5500_SPI_READ | W5500_SPI_VDM_OP);
if(!WIZCHIP.IF.SPI._read_burst || !WIZCHIP.IF.SPI._write_burst) // byte operation
WIZCHIP.IF.SPI._write_byte((AddrSel & 0x00FF0000) >> 16);
WIZCHIP.IF.SPI._write_byte((AddrSel & 0x0000FF00) >> 8);
WIZCHIP.IF.SPI._write_byte((AddrSel & 0x000000FF) >> 0);
//ret = WIZCHIP.IF.SPI._read_byte();
else // burst operation
spi_data[0] = (AddrSel & 0x00FF0000) >> 16;
spi_data[1] = (AddrSel & 0x0000FF00) >> 8;
spi_data[2] = (AddrSel & 0x000000FF) >> 0;
WIZCHIP.IF.SPI._write_burst(spi_data, 3);
WIZCHIP.CS._deselect();
WIZCHIP_CRITICAL_EXIT();
return ret;
As far as I can see, it has an option for burst as well, but it does not return anything (since it reading byte to be returned) and just keep writing three bytes: 0x00 0x01 0x08
I tried to modify burst part to write/read four bytes and return one as following:
uint8_t WIZCHIP_READ(uint32_t AddrSel) //This function is altered for SPI Burst operations
uint8_t ret;
//uint8_t spi_data[3];
uint8_t spi_data[4];
WIZCHIP.IF.SPI._read_burst(spi_data, 4);
ret = spi_data[3];
return ret;
In this case I can have two UDP sockets open, but if I try to send out some data, using sendto() in main cycle, it returns SOCKERR_TIMEOUT for first time and SOCKERR_IPINVALID for all attemts after that.
First, I wonder why WIZCHIP_READ is called if I haven’t registered reg_wizchip_spi_cbfunc(), and second if this function has burst operation section, how it is supposed to be returning value?
Any ideas?
