I am using io6Library to communicate with w6100 and when I do getSHAR(), etc. I always get 1 2 3 as first 3 bytes in the response. So the actual length of received data will be 3 + 6 in case of SHAR but io6Library only considers read len to be 6. what is this 1, 2, 3?
When I checked the sample codes, it doesn’t seem like other 1st 3 bytes (1,2,3) are handled in io6Library?
Then how do EVB test codes using io6Library work when these 1st 3 bytes are not handled by the library. I also didn’t see handling of 1st 3 bytes in SPI read/write methods of codes given by WIZnet. I referred to w6100-evb-gcc-eclipse and W6100EVB_CUBEIDE.
For my host controller, I have modified my SPI read/write methods to ignore these bytes. Am I missing anything? Is there a way to stop WIZnet from sending host controller 123?
