Okay so a lot of the links herein still take you to the 1.0.0 version. This is NOT the latest.
THIS is the latest
https://wizwiki.net/wiki/lib/exe/fetch.php?media=products:w5100s:w5100s_ds_v125e.pdf.
Its still a train wreck but it MUST be better than 1.0.0.
For instance: getting this thing to work with these RING buffer - RX/TX buffer - and “MASK” hoo-haa means the memory map info is important.
Like this:
Then of course there is THIS:
Um : TX?
Um: Do I need to solder a ram chip on top of the W5100S?
(0xC000 ??? That’s over in the neighbors yard )
Um: Sn_TX_MASK. I know (NOW anyway) This is NOT a REGISTER you poke a value into. But isn’t the format sort of HINTING that it “IS”? It made me LOOK for one…
I’m hooked to the WIZ810SMJ (W5100S device) and writing/reading registers. There is NO SNEAKY INVERTERS in the SPI enable on THIS module. Working Parallel AND SPI using burst mode where desired. ( Unlike the W5100 that doesn’t support burst SPI ). I can ping it. So not only do my writes work, I also do get good READS.
Sending Network data. Just a blind transmit test… Now there’s a head spinner. SO I use my W5300 experience, Socket 0 and the power up 2K defaults. AND! The train wreck data and -
Poke in a DESTINATION IP and PORT, starting at 0x040C - 0x0412 (Burst)
Poke in 32 bytes of detectable STUFF (My_Data) starting at 0x4000 (Burst)
Poke in 0x0020 starting at 0x0424 (SIZE! Right? Wrong? Who knows )
Poke in 0x20 at 0x0401 (SEND command to socket command register )
Watching wireshark the entire time shows me [ nothing from my IP address ]
So I can write and read EVERYTHING as a further test - But I thought I was past that. I’m SPI and in the 100KHZ Super Safe Speed Range ( for now ) so no need for THAT suggestion.
Where am I off track please? The datasheet leads me to the weeds.
