w5500 arduino comunication problem
Hi I have two w5500 chinese ethernet module. one of them somtimes work and somtimes doesnt work. arduino says ethernet shield was not found. I think it is a spi problem but somtimes works good
i thing ethernet module could have spi frequency problem or oscillator problem
or cs pin and rst pin pull up.
am i right ?
how can i test According to Probable problems?
I use ethernet.h library
If you bought a module that we didn’t sell, I can’t say that it can work.
Because the schematic is unknown.
I think you should check the SPI waveform with an oscilloscope.
Please capture the waveform that reads the Mac address and upload it, and I’ll check it with you.
